Hello TI support team,
I am designing a device with BQ51013B and I need to cut the power after battery become fully charged. I know having EN1=EN2=1 for some charge pads doesn't work and still I might get the power. I can try playing with TS/CTRL pin as well to cut the output power (if this assumption is correct). but my question is in case I could disable the RX output while the device is on charge pad, how can I detect if the device still remains on the charge pad to activate the RX after the battery gets to some low level like 90-95%?
Thank you,
Amin.
