Customer have 3000pcs TPS22916BYFPRl, and all top marks are R0,pls refer to the below pic. but the device marking in datasheet should be BA or R, can you confirm is it is correct.
Hi Lidong,
The zero added is perfectly fine; It is still the TPS22916BYFPR (no I) device. The zero was likely added for internal traceability purposes, and is nothing to worry about.
Thank you for reaching out to confirm!
Elizabeth
