Other Parts Discussed in Thread: TPS56339, TPS563211, TPS562211
TPS561201's current protection is to monitor the low-side FET drain to source voltage. However, if the overcurrent protection occurs during the high side on-time, OCP could not be enabled. Could you please help check if there is any other pin to pin or similar option with TPS561201 to provide high side FET protection? Thank you.
