LM25141-Q1: LM25141-Q1
Part Number: LM25141-Q1
i have a generic question:
Do you have any guide for selecting the soft start time( or capacitor value) during the initial design of the power supply?
i have generally selected this value with thumb rule. Do we have a guidance precisely showing the soft start duration needed in any design. Keen to understand this concept in detail!
regards
Shreeharsha K
Robert Bosch India
  • Hi Shreeharsha,
    The soft-start time is typically in the range of 2-4ms and set by the soft-start capacitor (basically a current source charging a cap to a certain reference voltage).
    The main concern is the current into the output caps for a given dv/dt at startup. This current = Cout*dv/dt should not cause current limit to engage (especially if there is also a resistive load present at startup). In general, a higher output cap value requires a longer soft-start time.
    Tim
