Other Parts Discussed in Thread: BQ25100, BQ25170
I want to know what the consequences of setting the ISET programming current below 50 mA is. We want to set our programmed current to 41.5 mA mA by using a 13 kOhm resistor. The reason we want to do this is that our power supply isn't specified for 50 mA.
So why is the lower limit 50 mA? Is there something else that goes out of spec (pre-charge current or termination current)? Or is the programmed current not quite what you set it to.
Alternatively we could try setting the programmed current to 50 mA but our power supply would likely drop below 5V. Would the BQ24040 work OK in this scenario.
