Please review the design of LMR16030PDDA attached below.
And let us know whether this design is efficient to give Vout=28V.
Hi
the schematic looks OK for me, pls make sure the pull up voltage of Pgood pin is lower than its rating.
Hi Daniel,
You told to provide pull up Voltage of Pgood pin lower than its rating.
Please explain this clearly.
HI
PGOOD max voltage is 7V, so make sure not tie to Vo or other voltage higher than 7V. recommend 5V voltage as pull up voltage
