Hi, I need the following thermal parameters for TPS7H2201-SP
- Thermal Conductivity Coefficient (W/m.K)
- Heat Capacity (J/kg.K)
Thank you,
Thank you,
Hi Elif,
I will reach out to our thermal modeling team and update you here once I hear back from them.
Typically we report the following thermal metrics. Would these be sufficient for your needs?
RθJA | Junction-to-ambient thermal resistance | °C/W |
RθJC(top) | Junction-to-case (top) thermal resistance | °C/W |
RθJC(bot) | Junction-to-case (bottom) thermal resistance | °C/W |
RθJB | Junction-to-board thermal resistance | °C/W |
ψJT | Junction-to-top characterization parameter | °C/W |
ψJB | Junction-to-board characterization parameter | °C/W |
More information and definitions on the thermal metrics above can be found here if needed.
Sarah
