Hi ,
I am looking for LP5569 Sample code with use case LED engine , direct control of LED from MCU. I found one example code with file name '0777.0904 lp5569_i2c_master_w_multibyte-master_code_MSP_EXP432P401R' and doesn't found suitable . It would be good if you can share some more examples for LP5569 Driver. Also let us know to generate & load instructions to LP5569 internal SRAM if it is present customized board.
Hareesha
