Part Number: LM5122
Is it possible to control by putting resistors Rs on the low side and detecting the current with the CSP pin and CSN pin?
Part Number: LM5122
This is a differential amplifier, theoretically you can put it on the low side, but I don’t recommend you to do this.
On the low end, you need to be careful to deal with the effects of switching noise.
In addition, switching noise will let negative voltage, you need to pay attention.
You need to do a careful evaluation on the system board.
