Hi Sir,
The testbench has been configured for VIN = 12V, Vout = 1.05v, IOUT = 4A
Although it is V (VO) after simulation, it does not seem to reach 1.05v.
Is it a normal analysis result?
Hi Sir,
Hi Frank,
can you try the settings I mentioned in this reply about speed level and accuracy? I had seen a similar issue with another device.
Amod
Hi Amod,
Thank you for your patience.
I try to the suggestion in your attached post.
Please click PSPICE menu -> Edit simulation profile. speed level to 3→0.
It does not change to the analysis ripple.
Do you have any other suggestions?
Thanks a lot.
Hi Frank,
Is it possible to share before/after waveforms (speed level changes of 0 and 3)? And, also the screenshot of the options like example shown below? I do not see any issues with the model but more of a simulation tool convergence options issue here.
Amod
