Because of the Thanksgiving holiday in the U.S., TI E2E™ design support forum responses may be delayed from November 25 through December 2. Thank you for your patience.
LP2981: current limit and thermal shutdown
Part Number: LP2981
Hi team
I understand that LP2981 has current limit function and thermal shutdown, but not sure when these would work.
Could you tell the specific value when the current limit & thermal shutdown would operate?
Noriyuki Takahashi
  • Hi Noriyuki,
    The EC table specifies the peak output current (i.e. the current limit) for both the LP2981 and LP2981A devices:
    Thermal shutdown for a part with abs max Tj=150C is typically 150C - 175C. It is not always a precise number (especially with these older devices), but it is guaranteed that the thermal shutdown is above 150C, which is why we say to not exceed 150C.
    Nick
