Part Number: UCC28070
Hi all,
I am designing an interleaved pfc and as controller I will use the UCC28070.
I have a question about the current sense transformer reset network:
I know the common solution suggested on the TI datasheet made with a diode and a resistor on the secondary side of the current sense transformer, but do you know if it is possible to design a reset network on the primary side made just with a diode? Would this have any advantages respect to the standard solution made on the secondary side? I ask this because the power module I will use for the pfc is equipped with a diode thought just for this purpose and I wonder if it worths trying to use it.
Thanks in advance for any suggestion ot comment.
Matteo
