Part Number: BQ24045
Hi Ti Team,
we use the BQ24045 charging ic in our design.
Due to some problem charging ic pin 8 is set as Low state after connect the battery to the pcb.
for that we also check the different battery voltage level and also put battery as long time like 3-4 hours but after also ic not detecting the battery and pin 8 is set in Low state they not change in High state after connect the battery.
our battery specs. is 800mAh,4.2V.
so please you have any suggestion let me know?
