TPS745-Q1: Searching TI solution
Part Number: TPS745-Q1
Other Parts Discussed in Thread: TPS746-Q1
Hi Team,
There is a good new that we could DIN TI product!
Customer is looking for the replacement of  TPS74518PCQWDRVRQ1
Please help suggest a newer IC, THX
  • Hi Kygo,
    This is one of our newest devices already. Can you provide customer use case (VIN/VOUT/IOUT) also how are they using the PG pin? For instance, I see you chose the C-version of this device which has the push-pull output for PG instead of standard open-drain.
    Something for you to maybe look at would be the 1A variant - TPS746-Q1.
    regards,
    Wilson
