Can you please provide the tolerance(min and max values) for the charge current of TPS57114QRTERQ1
Thank you
Thank you
Hi Kavana,
Unfortunately, I could not get this information as it is an old part and inherited from another product line.
However, the customer can still refer to Figure 12 in TPS57114 datasheet to get more details on Charge current over temperature.
I hope this helps.
Febin
Hi Kavana,
I personally do not recommend using this part in any new projects as it will be discontinued soon.
I recommend to have a look at one of our new devices, TPS6281x-Q1. https://www.ti.com/lit/ds/symlink/tps62810-q1.pdf
Febin
Hi Kavana,
As this is a pretty old part, I could not find further information. As I mentioned earlier, figure 12 in the d/s gives an overview of charge current over temperature.
You may use this as a reference. It looks like the tolerance is 5% for 5V Vin.
I hope this helps.
Febin
