Hi Tuan,
Sorry for bothering you again. Recently I am learning TPS92691 for my review presentation, so I still have some questions:
1. How to calculate the 1000:1 PWM dimming ratio? I know the ratio=1/minimum duty cycle=PWM minimum on time/T. But you said the PWM minimum on time depends on the system, and the PWM frequency can be 100Hz~1KHz. So how does the 1000 come from?
2. I want to know how to select low-side series NFET or High-side PFET for PWM dimming. Why the 001EVM choose high-side? Is it for short circuit protect consideration?
I know to control the slew rate the low or high demands different circuit design, is it an important issue to consider?
3. I found if set average Iout=300mA, peak Iout=400mA, duty cycle=75%, the PWM dimming efficiency is lower than analog Iout=300mA.
Is it normal and what cause it?
Thanks again!
