Hi Team,
My customer is debugging the TPS43060 chip and found a large ripple output (No load around 90 mV), Please find schematic diagram of the TPS43060 attached. Do you have advice for this issue?
Hi Team,
Hi Eric,
This seems running into the min duty cycle. Adding a dummy load should help. Actually the ripple is not that big on top of a 48V voltage rail, which is smaller than 1%, and the customer seems overconcerned about the ripple.
Youhao Xi, Applications Engineering
