Other Parts Discussed in Thread: TPS7A02,
Dear Power support team,
My customer is facing some problems with the utilization of the TPS782xx family for RF applications:
A significant noise generated of around 100 mVpp.
Previously, they were using the TPS7A02 and didnt have any problem.
Can you confirm that the TPS782xx are the same "good / efficient" than the TPS7A02 when used to power RF modems which can generate a lot of inrush current and which are extremely sensitive to noise?
I recommended:
- Checking the testing method: tip & barrel method
- DC bias of the capacitors
- Follow the Layout Guidelines
Do you have other recommendations?
Thanks and best regards,
Juan.
