Hello Expert,
I have question for datasheet's measurement result.
Our customer is looking for boost converter for following condition.
Vin=2.8~4.6V
Vout=approx.20V
Iout= single-digit mA
Then I simulated some device using webench and I found this device due to this device has good efficiency at lower than 1mA as attached report.
TPS61288_SIM.pdf
However, this sim report's efficiency data has huge difference against datasheet's result.
For example, simulated efficiency is higher that 96% at 1mA load condition but measurement result(Vout=16V, Vin=3.6V) is approxf. 70%.
So we'd like to know about why there is such a huge difference between simulation result and datasheet.
Would you tell me the root cause of causing this difference?
Kazuki Kuramochi
