UCD9090: Importing from UCD9090A to UCD9090
Part Number: UCD9090
I'm trying to figure out if I can downgrade our current design from UCD9090A to UCD9090 (due to the current component availability situation). The Fusion Digital Power Designer (7.6.1) tool should be capable of doing that based on what I see in this post: https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/1029160/ucd9090-further-questions-on-the-difference-of-ucd9090-and-ucd9090a?keyMatch=UCD9090%207%205%201
I try to follow the procedure described in https://www.ti.com/lit/an/slva908/slva908.pdf?ts=1633607450240 for importing the .xml file from our 9090A to the 9090.
When I try to import the file (UCD9090A .xml file) into the UCD9090 device, I get the following error:
Does that just mean that our UCD9090A design is using features that UCD9090 doesn't support or am I doing something else wrong?
