TPS54329E: P2P Solution Consult
Part Number: TPS54329E
Other Parts Discussed in Thread: TPS54339E, TPS54329, TPS54229E, TPS563211, TPS563200, TPS563212, TPS563231, TPS563202
Hi Team,
Customer wants to use TPS54329EDDAR to replace TPS54329DDAR because device shortage directly. I check D/S, the specs seems okay. Could you pls help us double check that? If not, could you pls recommend suitable one? Thanks
Stanley
    For the P2P solution , you can check TPS54329, TPS54339E and TPS54229E.
    For the other solution , you can use TPS563211 which is released last month , could have better supply and performance.
    and you can also check with TPS563212 (will release this month , 1.2MHz verison of tps563211) , TPS563202/1,TPS563231, TPS563200.
    Above sockets also have 2A version if you are okay with 2A .
    BRs,
    Young
