TL494: About the error amplifier of TL494
Part Number: TL494
Hi TI's team
Have a nice day.
If I only use one operational amplifier in TL494, how should I connect the other one to avoid the impact on our circuit?
Thank you very much.
  • Hello Alvin,
    The error amplifier outputs are diode connected, as shown here:
    So, if your application only requires a single error amplifier the unused amplifier must have it's output biased low: ground the (+) pin and bias the (-) pin to a low voltage (100-200mV) using a resistor divider to VREF.
    Eric
