Hi, everybody
How can I get TPS 65950 footprint?
Hi, everybody
I am not sure if I understand your question. The footprint details (same as package details) are available in the data manual. If you are looking for footprint to use in your layout then you can extract the footprint from the board files available on www. beagleboard.com
Beagle board uses this part and you can re-use and refer to the files for layout details as well.
there are allegro files on beagleboard, but when I use this file, Altium gives error. I think allegro files is bad on beagleboard.com
I know but I want to import to altium. I havent any problem now. I solved this problem.
Thanks.
Hello
You can import the entire allegro brd file from cadence to altium.
Once thats done, you can extract libraries from the converted altium brd file.
Cheers
Ajay
