Other Parts Discussed in Thread: LM34936, LM5176
Hello expert,
May we know the difference between LM5175 and LM34935? Could you provide comparison table for us? Thanks a lot!
Ann Lien
Hello Dehuan,
Customer is using LM34935 in the past and want to implement 2nd source with LM5175. Thanks for your comparison table and could you kindly help to double check if we don't need to change external component, which means BOM to BOM for LM5175 and LM34935 design? Thanks a lot!
Ann Lien
Hi Jason,
Similar answer. LM5176 can replace the LM34936 but not the other way around. The main difference is the voltage rating and operation temp but all other electrical performance should be the same.
BR dehuan
