Other Parts Discussed in Thread: TPSM82866A
hi Team,
Could you please help to check the Assembly site for TPSM82480MOPR is from which country.
Thanks!
hi Team,
Thanks!
Hi Grace,
Do you need to know the country of origin for the device? Or is there some issue/difference between the label on the ESD bag and the IC (as stated in the title of your post)?
Chris
The label on the box/reel should show the CCO (wafer country of origin) and the ACO (assembly country of origin).
Chris
I would also recommend to look into using the TPSM82866A instead of the TPSM82480. It is newer, much smaller and with better thermal performance.
Chris
Chris
we have gotten this part, but label shows ACO - TAWIAN, CCO - USA, however chip body marking shows I = Philippines.
Thanks for sending the picture.
I've clarified that the IC (which has the markings in the photo) is assembled in the Philippines, but the TPSM82480 device (of which that IC is a sub-component) is assembled in Taiwan. So, both the markings and ACO on the label seem correct. Does that clarify it?
Chris
