Other Parts Discussed in Thread: LM2776
My customer has used a similar type of device as the LM27762 before.
At that time, they experienced a problem that the negative voltage did not start up normally when the negative output was pre-charged to positive during startup.
LM2776 could have the same issue when OUT- is pre-charged to positive at startup?
If yes, to avoid the issue, what kind of workaround is recommended?
K.Hirano
