BQ25895: [BQ25895RTWR] Substitute Inquiries
Part Number: BQ25895
Other Parts Discussed in Thread: BQ25890,
Hi, TI Support Team
The customer was using the BQ25895RTWR product, but is looking for a replacement due to a delivery issue.
The product that has received inquiries from customers is the BQ25890RTWR product.
The product is confirmed to be PIN TO PIN.
Is it suitable as a substitute?
What is the difference, if any?
BQ25895RTWR and PIN TO PIN products are identified as BQ25895MRTWR, BQ25890RTWR, and BQ25890HRTWR products.
Which of these products is the best replacement for you?
Thank you for your quick reply.
Thanks.
MJ
  • MJ,
    BQ25890 should be the closest. The key differences are 1) OTG bit is enabled by default for BQ25895 while disabled by default for BQ25890. 2) In OTG mode, Q1 is off for BQ25895 (only PMID is OTG output) while Q1 is on for BQ25890 (both PMID and VBUS are OTG outputs).
    Ning.
