Hi Team,
The customer is asking about the fault pulse behavior, could you please kindly help to answer? Thank you.
- With reference to the description of Register #1 below, does all faults listed in the FAULT field result in a fault pulse?
- In case a fault is persistent, is there only one fault, or would there be periodic fault pulses?
- In the case where a fault occur during charging causing charging to stop, what is the expected state transitions on the STAT pin?
Mike
