Hi Sir,
could help check the TPS65941-q1 schematic and learn from you?
please kindly refer as attached
Hi Sir,
Hi Tommy,
The PMIC TPS65941212RWERQ1 needs to work together with TPS65941111RWERQ1 according to the document linked here.
Please let your TI FAE know if you need only one PMIC to power up your processor for your application.
Thanks!
Phil
Hi Harker,
There are much more details needed to give you our suggestion to use the PMIC to power up an ASIC; like VIN range and all output rails specs: voltage level; on/off sequence; load and ripple.
Please work with your local TI FAE to find the best PMIC device from TI portfolio for your application.
Thanks!
Phil
