BQSTUDIO: bqStudio
Part Number: BQSTUDIO
I have a need to log both Registers and Data Flash. where can I find documentation on how to do this, select parameters to log, set scan times, etc.
  • Hello Chris,
    It is best to log all parameters and at the default interval as battery charge / discharge is a long process and we want to capture as much data as possible.
    Both registers and Data memory tab have buttons to log data. On Data memory tab it is called autoexport
  • Hello Chris,
    You should be able to edit the logging rate by going into bqStudio on the top left there's a window tab, go to preferences then Registers. You can't select specific registers to log, it logs all important registers for debug and analysis.
    Sincerely,
    Wyatt Keller
