Part Number: BQ79600EVM
Other Parts Discussed in Thread: BQ79600-Q1
I have a BQ79600EVM attached to two 79616 EVMs. My driver does initialize the system similar to the UART example code. Specifically, I did not change any fault masks. I am able to read voltages, GPIOs, etc. When I do a single write to a stack device changing its customer CRC registers to make the check fail, NFAULT becomes active as expected. But when I just disconnect the daisy chain between 79600 and the bottom stack 79616, the NFAULT pin remains high. I would have expected it to become active due to a communication fault. What am I missing here?
Thanks for your support.
Best regards
Julian
