Other Parts Discussed in Thread: TL750L, LM2936, LM2931-N
This part is to be used in our design as an alternate part for the TL750. Our design does not tie the enable disable pin to enable. The datasheet does not say if the enable/disable pin has an internal pull down to keep the regulator enabled, if the pin is left floating.
Can you provide this detail?
