Could you please provide a solution? Thank you
could this helps? I can't try because the sheet is write protected. Can you try this?
support.microsoft.com/.../how-to-correct-a-error-bf801d0a-2a6e-44bd-a70e-0f780ae8f11e
Hi Alberto
I don't think the link is the right answer. Because from my side, using the same version as you, the result appears as below.
Are there other changes you have done on this tool since it's downloaded from ti.com?
Best regards.
I've found the solution:
in Italy we use comma instad of dots, so the settings of excel are creating errors when selecting values in this formula:
To fix the error I went in to options-> advanced settings and changed the separators as follows.
