HI
My company uses the lm5022 flyback
But I don't know where the parts calculation for the flyback.
Request a flyback datasheet.
Thank you
HI
Thank you
Hello Seung,
Thanks for reaching out. You can find the Excel Quickstart calculator for Flyback in the product folder of the device, under "Design tool and simulations", here the link to the file: https://www.ti.com/tool/FLYBUCK-FLYBACK-DESIGN-CALC
Kind regards,
EM
thanks for the reply
I'll just ask one more question
The data sheet says that when the cs pin of the lm5022 becomes 0.5V, it does not work.
So I shorted it to allow overcurrent to flow.
However, the voltage on the cs pin does not rise to 0.5V and the operation does not stop.
Can you tell me why??
(The red part of the attached circuit diagram was short-circuited.)
Hello Seung,
Thanks for your reply. At page 21 of the datasheet, section 8.2.2.9 you can find a description of how to select the sense resistor. The converter enters current limit when the voltage drop on the sense resistor is 0.5V, therefore in you case you might need to change the value of the sense resistor so that the converter enters current limit when the peak current reaches the value you want. Let me know if I can help you furthermore.
Kind regards,
EM
