TPS54618: Power supply IC Queries*
Part Number: TPS54618
Other Parts Discussed in Thread: TPS62090
HI I need an information on the time the Power supply Ics take to assert the PGOOD pin when there is a Fault in output (improperly regulated)
LM63625DQPWPRQ1
LM61440AASQRJRRQ1
TPS628112M
TPS6281126
TPS6281228
TPS74533P
TPS62090
TPS54618CQRTERQ1
TPS74517PQWDRBRQ1
  • Hi Jahnavi,
    I will take care of  your request and provide you the details as soon as possible.
    Alex
  • Hi Jahnavi,
    There are a few devices that are not BSR-LV.
    I provided you the times for our devices.
    LM63625DQPWPRQ1                Wide Vin team please answer
    LM61440AASQRJRRQ1             Wide Vin team please answer
    TPS628112M                               Power Good De-glitch Time for a high level to low level transition on power good 40 µs
    TPS6281126                                Power Good De-glitch Time for a high level to low level transition on power good 40 µs
    TPS6281228                                Power Good De-glitch Time for a high level to low level transition on power good 40 µs
    TPS74533P                                  LDO team please answer
    TPS62090                                    Power Good delay time ~150us
    TPS54618CQRTERQ1                Power Good delay time ~150us
    TPS74517PQWDRBRQ1            LDO team please answer
    Alex
  • Please transfer this thread to the LDO team after replying.
  • I have added the LDO PG times.
    TPS74533P                                Open-drain power-good output with ~7µs delay (min=1.5µs, max=10µs)
    TPS74517PQWDRBRQ1          Open-drain power-good output with ~7µs delay (min=1.5µs, max=10µs)
    Transferring thread to BSR-WV for their input
  • LM63625DQPWPRQ1                RESET edge deglitch delay ~17us(typical)
    LM61440AASQRJRRQ1            Glitch filter time constant for PGOOD function ~120us (typical)
