TLV62568DRLR(SOT563-6) curve analysis showed as below figure. Is it within the acceptable tolerance range ? Or it will cause unforeseen errors?
Hi Morris,
Sorry I did not understand your question and what exactly you mean by curve analysis? I can not see the curve very clearly if possible can you please attach the figure in a file/document form and label it also (what is x-axis and y-axis?)
Thanks and Best Regards,
Farheen
Hi Farheen,
Thanks for your reply. Sorry I did not describe clearly. First figure, x-axis is the force Voltage between SW(Pin4) and GND and y-axis is the corresponding Intensity. Second figure, x-axis is the force Voltage between VIN and SW and y-axis is the corresponding Intensity.
Thanks and Best Regards.
Morris
