Part Number: BQ76952
Other Parts Discussed in Thread: EV2400, BQSTUDIO
What would normally be the manufacturing process (when OTP programming is included)?
Since the OTP memory includes calibration, I expect that you’d need to connect the BQ76952 to the cells first to load all the values to the registers. To write to OTP, you’d need to disconnect the cells and plug in an 10-12V supply. But when you disconnect the cells the BQ76952 loses power, so you lose your register values. Would you just need to export the export the config, and then just re-load it afterwards to do an OTP write? Is the 10-12V supply applied at the cell inputs or is there usually a BAT connector for this purpose? The process seems awkward and I feel like I’m missing something.
