Part Number: TPS23881
Hi All,
A device uses TPS23881 without MCU. The AUTO pin resistor of TPS23881 is 7.68kΩ (4-pair 90W). We found that TPS23881 cannot supply power to a PD when it is connected with a PD which only supports IEEE802.3af. If the connected ethernet cable (4-pair) is replaced with 2 pairs of wires,TPS23881 can supply power to the PD. If a PD supports IEEE802.3at/IEEE802.3bt, TPS23881 can supply power to the PD with 2-pair/ 4-pair wire. What reason caused it? How to fix it?
I look forward to getting your reply.
Thanks .
