I am trying to implement the Hysteretic Fan Control based on information on page 32 of the UCD90910 Fan Controller datasheet. I cannot find where to set TempOn and TempOff Levels within the TI Power Fusion GUI. I also cannot find the MEAS_TEMP command. Can you please tell me where to find and set these up?
Also, is it possible to set up hysteresis for the Logic Controlled GPOs? I have a heater connected to a GPO pin that needs to turn on when one of the rails reads below a certain temperature and turn off when it goes above that temperature. When the temperature hovers around this trigger temperature, the heater turns on and off causing the current to spike. Is there a way to avoid this by ramping up and down the turn on/off time for the logic controlled GPOs or set one value for turn on and another for turn off?
Thank you.
