Hi team,
The SOH load rate is set to 5, 0.2C charge and discharge, and then the ratio of SOH FC@25C Q to design capacity is SOH, 91%. The customer has the following questions:
1. SOH FC@25C Q is related to what states?
2. How to learn SOH FC@25C Q very close to the design capacity, ratio is close to 1?
3. Does SOH FC@25C Q change with charge and discharge? Is it continuously falling or changing?
Could you help check this case? Thanks.
Cherry
