Part Number: BQ76952
When communicating with the bq76952 using I2C my host has 5 vdc available for the pull ups. Therefor I do not require reg1 or reg2 for anything. Can i leave reg1, reg2 and regin pins open, not connected to anything?.
Hello Corbin,
See Section 16.6 Unused Pins of the datasheet to see what to do with unused pins. For REG1/REG2 you can leave them floating or connected to VSS, for REGIN you should connect it to VSS. Follow the datasheet suggestions.
Luis Hernandez Salomon
