Other Parts Discussed in Thread: GPCCEDV
Do you always recommend to put the battery for learning phase at least once, to get the accurate SOC, SOH values?
Hello Chandrakala,
I would recommend doing a learning phase to make sure your system is working correctly, but it would not be a requirement for all the batteries to do this, since it should be updated over time in the field whenever there is a qualified discharge.
Sincerely,
Wyatt Keller
Hello Chandrakala,
It does not matter what chemistry or type the battery is, after running the GPCCEDV tool you should not need to do a "learning" cycle on the battery, it will update over time in the field.
Sincerely,
Wyatt Keller
How to perform logging the battery discharge process for various temperatures to get 6 log files from GPC packer?
Hello Chandrakala,
You would need to use a temperature chamber and a electronic load.
Sincerely,
Wyatt Keller
