Hello TI Experts,
I am Using UCC27714 IC for my Totem pole line synchronous Mosfet Switching. The Resistors and capacitors values are marked in the below figure
The HO PWM obtained is given below
Why there is a slop present in the top side of the PWM ?? also the LO PWM obtained is a perfect square shaped one but do not have the magnitude of 12V
LO PWM
Device Used : STW77N65M5
Diode : MURA160T3G
Switching Frequency : 50Hz (AC Line Frequency)
I am expecting a good support from ur side to sort out my issue !!!
