TL783: Solution to replace TL783CKTTR
Part Number: TL783
Hi sir,
Due to poor supply of TL783CKTTR , could you pls kindly suggest P-P solution to replace TL783CKTTR ?
It would be great if you can provide the option with better inventory.
Thanks a lot!
BR,
Sean Liao
  • Hey Sean,
    Some of the p2p options are the TLV1117CKTTR (inventory in the store), LM1084IS-ADJ/NOPB (a few units in store), LM1084ISX-ADJ/NOPB (inventory in the store), LM1085IS-ADJ/NOPB (out of stock), LM1085ISX-ADJ/NOPB (out of stock), LM317KTTR (out of stock), and LM317KTTRG3 (out of stock). These most likely not all work depending on application, however some do have inventory on TI.com currently, but keep in mind that changes hourly.
    McKyla
