BQ77915: Protection in IC - to take care of Charging Mosfet failure (MOSFET failed and shorted internally )
Part Number: BQ77915
Other Parts Discussed in Thread: BQ7718
In our BMS,  we had  a few failures in which charging MOSFET failed . Unfortunately when failed , MOSFET got shorted internally  and charging continued. This can cause cells to over charge.
Charger has a maximum voltage limit,  which will help  to some extent. But if the all the cells are not balanced due to aging,  there is a chance that a few cells will go to  high voltages.
Any suggestion to protect cells from overcharging in such cases ?
(I know Mosfet selection/design should ensure Mosfet will not fail, just trying to look for a fail safe option).
Anil
