[FAQ] TPS25947: What is the difference between TPS25947,TPS25946,TPS25210 and LM73100 ?
Part Number: TPS25947
Other Parts Discussed in Thread: TPS25946,
  • Differences between TPS25947,TPS25946,TPS25210 and LM73100 can be found in below table:
    Features
    TPS259470A/L
    TPS259472A/L
    TPS259474A/L
    TPS25210A/L
    LM73100
    TPS259460A/L
    TPS259461A/L
    Product Category
                                                    eFuse
    Ideal Diode
                         eFuse
    Vin operating min
        2.7V
    Vin operating max
    23 V
    23 V
    23 V
    5.7 V
    23 V
    23V
    23V
    Vin abs max
        28V
    Max Current
    5.5 A
    5.5 A
    5.5 A
    4 A
    5.5 A
    5.5A
    5.5A
    Rdson
    28.4 mΩ
    28.4 mΩ
    28.4 mΩ
    31 mΩ
    28.4 mΩ
    28.4 mΩ
    28.4 mΩ
    Reverse Current Blocking
                                        Always, Zero DC reverse current
    While Disabled
    While Disabled
    Bi-directional current
                                                            No
    While Enabled
    While Enabled
    Input Reverse Polarity Protection
                                                           Yes
    No
    No
    Overtemperature protection
                                                           Yes
    Slew Rate control (dVdt)
                                                           Yes
    Analog Current Monitor
                                                           Yes
    Overvoltage protection
    Adjustable OVLO
    Pin selectable OVC – 3.7/5.7/13.8V
    Adjustable OVLO
    Pin selectable OVC – 3.7/5.7V
    Adjustable OVLO
    Adjustable OVLO
    Adjustable OVLO
    Overcurrent response
    Adjustable Current Limit
    Adjustable Circuit Breaker
    N/A
    Adjustable Current
    Limit
    Overcurrent blanking timer
                                             Adjustable
    N/A
    Adjustable
    Adjustable
    Short-circuit protection
                                           Always ON
                                           Adjustable & Fixed Thresholds
    Only in Steady State
    Fixed Threshold
    Always ON
    Always ON
    Fault response
                               Auto-Retry & Latch-off options
    Latch-off
    Priority PowerMUX control
    Yes
        No
    Fault indicator
    Yes
        No
    Yes
    Power Good indicator
    No
                                                        Yes (Adjustable threshold)
    No
    Package
        QFN-10, 2 mm x 2 mm, 0.45 mm pitch
    Features
    TPS259470A/L
    TPS259472A/L
    TPS259474A/L
    TPS25210A/L
    LM73100
    TPS259460A/L
    TPS259461A/L
    Product Category
                                                    eFuse
    Ideal Diode
                         eFuse
    Vin operating min
        2.7V
    Vin operating max
    23 V
    23 V
    23 V
    5.7 V
    23 V
    23V
    23V
    Vin abs max
        28V
    Max Current
    5.5 A
    5.5 A
    5.5 A
    4 A
    5.5 A
    5.5A
    5.5A
    Rdson
    28.4 mΩ
    28.4 mΩ
    28.4 mΩ
    31 mΩ
    28.4 mΩ
    28.4 mΩ
    28.4 mΩ
    While Disabled
    While Disabled
                                                            No
    While Enabled
    While Enabled
                                                           Yes
    No
    No
                                                           Yes
                                                           Yes
                                                           Yes
    Adjustable OVLO
    Adjustable OVLO
    Adjustable OVLO
    Adjustable OVLO
    Adjustable OVLO
    N/A
    Adjustable Current
    Limit
                                             Adjustable
    N/A
    Adjustable
    Adjustable
                                           Always ON
    Fixed Threshold
    Always ON
    Always ON
    Fault response
    Latch-off
    Yes
        No
    Fault indicator
    Yes
        No
    Yes
    No
    No
    Package
