Part Number: TLV431
I am using the TLV431 as a comparator in open-loop mode. I know that V_ka(low) is "approximately" 2V. This application note shows the change in V_ka(low) over current and temperature:
https://www.ti.com/lit/an/slva987a/slva987a.pdf
What I cannot find is any mention of the tolerance of V_ka(low) between different parts. My temperature and I_ka will be very consistent, but I want to know the minimum and maximum V_ka(low) that I can expect across multiple units. I plan to make use of the analog output voltage (so, not a matter of converting to a binary output), thus I need to know the min and max voltages.
