Other Parts Discussed in Thread: LM1085
We have one important question, it should be a safety solution. We need sensor to install in two applications.
- Indoor Application: In this case, sensor will be installed in a room near to the Nitrogen, Ammonia gas cylinders. Sometimes leakage(or normal small leakage) may happen. Leakage may cause corrosion.
- Outdoor Application: In this case sensor will be installed in outside open space environment near to the Nitrogen, Hydrogen, Ammonia gas cylinders. Sometimes leakage may happen and rain will fall on the sensor.
