Hi team,
Could you comment on whether bq35100 is the most suitable solution for this application? Thanks!
1. Battery type: SB-AA11. https://www.lh.pe/file/Tekcell-Catalog.pdf
2. Configuration: 1S2P
3. Key requirement:
- We want to know when the battery needs to be replaced before it runs out
- Low power consumption in idle mode, < 80uA
4. The problem to be solved before: the accuracy issue from the method of only monitoring the voltage, because the voltage is different at different temperatures.
Sam Ting
