We designed a li-po battery charging section with 1amp charging current.
The battery charges at 1amps while the system requires additional 500mA current to drive leds and a boost converter.
My query is that since i set the charge current 1Amp and the system requires additional 500mA,then how will the system power path be managed?
Will the power path be able to deliver 1.5A total current i.e. 1A battery charge + 500mA system current?
